So I wanted to start a build thread on building an Oldsmobile 350 Turbo. I have an Olds 350 pulled from a 76 Olds cutlass brougham. So there not windowed mains. With obvious specs like 8a heads cast everything...etc. I thought I wanted a future N/A engine but I think if its worth any thing id be more into a turbo'd gbody.
So all the parts I had in mind to build a W30 350 out the door.
I am definitly not going to go all in at once. As everyone knows not every thing goes as expected when building engines.
So specific parts im going to need help locating are
1. Decent exhaust mnifolds for a T/C Olds350
2. A turbo specific cam designed for T/C Olds350
3. Heads? 8a heads are good because they have lower comp ratio. But I loose some +points due to poor flow.
I dont plan on using tons of boost to make power (8psi) so other areas would have to be the power adders.
