The parking paw isn't aluminum it wouldn't live.
How does a parking pawl work?
The parking pawl works by engaging a metal pin "pawl" into one of the notches of a metal ring that is attached to the transmission's output shaft when the shifter level is placed in the Park position. When the pin is in this position, the output shaft is prohibited from turning, which in turn prohibits the drive wheels from turning. Moving the shifter out of Park disengages the pin, which frees the output shaft and drive wheels to turn freely.
Note: Relying solely on the transmission's "P" Park position and the parking pawl to keep the vehicle from rolling when parked places undue stress on the pawl and other driveline components, which can cause excessive wearing of the pawl and lead to premature failure.
Symptoms of a worn or broken parking pawl
If your vehicle rolls forward or backward more than an inch or so after placing the shifter lever into "P" Park, the parking pawl may be badly worn. If your vehicle rolls more than a couple of inches, or rolls freely, after placing the shifter into Park, the parking pawl may be broken.
Note: In a rear wheel drive vehicle, a worn-out universal joint (U-joint) also causes excessive roll after the shifter is placed in the "P" Park position. In fact, a worn out U-joint is much more common than a worn or broken parking pawl. Therefore, you must rule out the universal joint as the cause of excessive roll before replacing a parking pawl. The cost to replace a U-joint is less than $50. The cost to replace a parking pawl is at least $500 (and can be much higher) unless you do-it-yourself.
IMPORTANT
When parking your vehicle, SET THE E-BRAKE BEFORE SHIFTING INTO PARK, especially when parking on an incline. This way, the weight of the vehicle is held by the e-brake rather than the parking pawl. Following this tip will eliminate the parking pawl from becoming lodged and subsequently causing your shifter lever to lock in Park
► What is a
parking pawl?
► How does a parking pawl work?
► Symptoms of a worn or broken parking pawl
► Parked on an incline and shifter stuck in Park
► Parking pawl repair information and cost
