Turbo 350 speedometer gears
gbodysupreme
32
10
8
Pittsburgh, PA
So I upgraded the 7.5" axle in my 85 Cutlass Supreme with a 3.73 limited-slip gearset, and am now having a hard time figuring out how to get my speedometer to read properly. It has an 18-tooth drive gear, and no one seems to sell a driven gear to get the speedometer close. I just want to be able to go over 65mph without breaking stuff (not that 85 is much better)
MrSony
6,828
6,734
Des Moines, Iowa
I have 3.42s, 26.1" tires (235/60/15), and put a 17/45 set in. Dead on. Those calculators above will certainly help though.
Drkuhar
512
912
Girard, IL
I just went through this. take the tailshaft off and change the drive gear. Its very easy You will not get close enough changing the driven gear alone. . I got my drive gear, 5 driven gears, and new bullet carrier for 28.00 on ebay.
Drkuhar
512
912
Girard, IL
Here is some pics. 4 bolts take tailshaft off. Push clip down swap drive gears and put tail shaft pack on. Used gear calculator to pic closest driven gear. My th350 with 26.6 with 3.42 gears was a 7 drive 18 driven gear.
