CX kits are historically garbage. There was a video of hotrod garage where they made a turbo LS 2nd gen and basically ended up chopping the whole thing up. Not sure about the G body twins kit, but I would be surprised if it didn't take significant redoing.
There are guys that will sell a fabbed kit using truck manifolds and piping. It's a turbo LS g body, if you want a bolt in or "light" fab kit its already done. There really is no benefit for fabbed manifolds. These do have all the piping but cast manifolds are proven to work well past 800hp. Stock manifolds flipped facing forward with a Y pipe or a trick/holley passenger side cast manifold in
grand national style and a single borg S475 or similar in the passenger fender well battery hole with a 4" down pipe either out the fender or where the AC box goes is proven to work pretty well.
Twin turbo setups are cool, but if you arent making over 800 the extra tubing, oil lines, exhaust, and all that stuff just isn't worth it. There is the room in a G body to package a big single and they spool fine.
