Turbo set up and oil pan
rizo3506
24
I have two question
what oil pan will work good that doesn’t break the bank for a 5.3 ls swap
Also what turbo kit or setup do you guys have for your Gbody’s that Also isn’t to expensive
Built6spdMCSS
5,695
9,502
Florida Beach
Pull up a chair and take a few minutes here..
Reactions: 4 users
Rodknok
210
577
I'm running the holley 302-2 pan and it works quite well. They make knockoffs that can be had for around 200 now. As for the turbo drain pan the 302-3 it will not work with our crossmembers so it leaves you with a drain problem as the front of the 302-2 isn't tall enough to tap a drain.
I opted to use a drain in my front timing cover to resolve this issue.
64nailhead
Goat Herder
Dec 1, 2014
5,659
12,059
Upstate NY
Do you want to make stuff or buy stuff that bolts on? And is this a daily driver or a strip car?
