Turbo400 build.
87cutty
106
2
Has anyone tried to beef up their own trans before? I have looked at some videos and they all seem very technical. I have a th400 looking to make 500-600hp from a 468 bbc. Not much stuff unless u wana spend 1400 bucks.
lilbowtie
3,460
3,965
Canton Mi
As long as your not afraid to get into one go for it. They are a very simple transmission and easy to work on. There is a book out by Ron Sessions (How to work with and modify the Turbo 400). I'm not a trans man but have built 7 performance 400s (2 trans brake) with this book w/o any problems and they are still going.
87cutty
106
2
Thx man! That makes me feel better bout it. What are some special tools that ur average man's garage wouldn't have that I would need for this project?
lilbowtie
3,460
3,965
Canton Mi
Not too much out of the ordinary. A slide hammer to pull the front pump, Some bushing drivers (I made my own) snap ring pliers, a 3/8ths- 3/8ths thin wall 12 point socket for center support (could be an Allen head) some sort of spring compressor for clutch pistons (pair of c clamps will work-I adapted my drill press) dial indicator and torque wrenches (in lb) I did buy a trans holding fixture for the bench (could make one). You probably have the rest.
87cutty
106
2
Thx!
Bar50
1,180
870
Tulsa, OK
Yeah, buy a spring compressor press for $60 off ebay. Some snap correct ring pliers. Any of the rebuild books. Need a 32 element direct drum from a 4L80 and your choice of shift kit.
There are a few tools for a less than $100 that would make it awesome.
