you have to remove the cluster....you'll see the light bulb holders that are removed by turning them untill the keys line up so you can remove them...then you just pull the bulb from the holder and install a new bulb and install it into your cluster.....you might want to change all the bulbs at the same time to save you the trouble of having to remove the cluster as each old bulb burns out....and if you don't now that I suggested it it's guaranteed that the old bulbs will burn out...lol
thanks. i've gotten as far as getting the faceplate(clear plastic) out but i can figure out how to get the actual speedo out to get to the bulbs. oh btw i have to granny cluster.
