Turn signal issue
Young0utlaw81Cutlass
158
21
Dallas Tx.
Can any body help me fix this small problem I check my turn signal fuse it was burn so i put in a new one and check my flasher but it's still don't blink just turn on does it have a relay flasher?
malibujustin
333
424
Looks like you are missing a flasher on bottom right of pic on fuse panel?
Ribbedroof
4,861
6,887
Wellston, OK
Check the bulbs, on old cars like this they were set up to stay lit and not blink when one of the lamps in the circuit was out.
Ribbedroof
4,861
6,887
Wellston, OK
Should be 2 flashers, and you should check the bulbs for shorted filaments and correct type/trade number. Strange things happen with the wrong bulbs in the sockets.
malibujustin
333
424
I know there no flasher just one on the upper left side?
There should be one on bottom right also. Had problems on my sons malibu similar to yours and was missing flasher. Installed both flashers...problem fixed. Also as ribbedroof says check all your bulbs to and grounds.
  • Dislike
Ribbedroof
4,861
6,887
Wellston, OK
If you try the hazards, do you hear anything? Sometimes the flasher will make one click only...same for signals. That would tell you if the flasher(s) were present in the circuit.
Seems like I recall later G bodies sometimes had one of the flashers in another location and did not use the second cavity in the fuse panel.
158
21
Dallas Tx.
It was working fine i check the flasher with a circuit tester see if power was coming but there no power? And all bulbs on back lights are good.
158
21
Dallas Tx.
The car came with only one I was wondering why it only had one how can I add another one do I need take all the fuse panel off?
