Turn signal problems...need help!
Mahlon Entz
19
12
erie
Lights and 4 ways are working on my 79 regal sport coupe but i have no turn signals. I checked my blinker relay and it's good, no power even reaching it after checking with a test light. Any ideas on what the problem is??
Slowpoke
582
1,218
I'm sure someone will chime in. An introduction would be nice.
Mahlon Entz
19
12
erie
I'm tex. Live up in erie pa.
Just swapped my pick-up for a regal with a transplanted 305. It needs tlc, alot of interior and some body work. It was already gutted for floorpan replacement when i got it. Really excited about turning this into a street beast but as i said before, this electrical issue has me stumped.
Slowpoke
582
1,218
Sweet I have a regal as well.. Not sure what your problem is , but there is a ton of knowledgeable people in here.. They will get you right! Hope you stick around.. And a big welcome to the best gbody site .
Mahlon Entz
19
12
erie
Thanks man, i really appreciate it! I hope i get some direction in this one!
If i knew how to send a pic i would..
Slowpoke
582
1,218
Have you checked the harness going into the column itself? Making sure good contact? Make sure you have the correct bulbs in there too
Mahlon Entz
19
12
erie
Have you checked the harness going into the column itself? Making sure good contact? Make sure you have the correct bulbs in there too[/QUOT
I haven't checked the bulbs. I'm assuming they're Right if they work using the 4 ways. It must be a bad connection Somewhere, i was hoping it was something easy and i wouldn't have to tear my dash apart. Whoever swapped the motor left me with a bit of a mess in the wiring dept..lol
Slowpoke
582
1,218
You'd be surprised what a wrong bulb will do.. I'm assuming you have checked with a light tester on the harness with outv the bulb?
