i just swapped my column out for another similar year (col. shift, cruise, tilt, wiper delay) this evening.
went well, took about 1.5 hours since my kids were constantly interrupting me...anyway, after I finished and tested everything, the turn switch is out of whack.
The left turn clicks down and works fine , but the right signal will not click up.
If you hold the stalk up (right turn signal position) it will not work either, like there isn't enough room for the mechanism to activate the right signal.
BUT if you turn on the left signal, and immediately hold the stalk up in the right-turn-signal position, the Right signals will work....only while you are stilll holding it up, Once you let go, they shut off, like being in the neutral (off) position.
Anyone have a clue as to how to fix this?
