Turn Signal Switch replacement part (85' Cutlass Supreme)
Javi
n00b
Mar 7, 2018
4
Need help with correct Turn signal switch part number (not turn signal lever) I keep getting 2 different numbers also indicates with and without cornering lights are they referring to side marker lights? totally confused 🤔
8,195
17,595
Assuming G47??? If so, you do not have cornering lights. GM p/n 1997983 is the switch you need if you have tilt wheel and delay wipers. (ACDelco # D6222).
Or equivalent.
Javi
n00b
Mar 7, 2018
4
Or equivalent.
Thank you really appreciate it 👍🏾
