Turn signal switch won't lock to right.
Michael Miller
15
14
83 malibu wagon turn signal switch won't lock or turn on for right side. Left clicks on fine. Is this the switch?
MrSony
6,826
6,730
Des Moines, Iowa
Probably broken. Not hard to replace, you need a steering wheel puller, and a lock plate removal tool.
RegalBegal
705
747
Goldsboro, NC
You probably can get away with just replacing the turn signal cam. cheap part, Autozone usually carries them as a HELP! kit.
MrSony
6,826
6,730
Des Moines, Iowa
Yep. And both tools are like 15 a pop, should also be in the help isle. Or they should at least have em on hand. If you also get a pivot pin removal tool, you'll have all 3 necessary tools (besides an E8 socket) to fix a floppy tilt wheel. :D
Michael Miller
15
14
You have to pull the wheel for cam or switch right? If so I may just swap them both while it's apart.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Michael,
Chances are the switch is still good, and they do last a long time. I think by changing out the cancelling cam, you'll be good to go....and they're cheap, too.
The cams are more susceptible to breaking than the switch is.
Michael Miller
15
14
Michael,
Awesome. Thanks
oldsmobile joe
2,067
3,053
mpls
you most likely just need to springs that are pictured in regalbegal's post. you'll know more once you get inside. it not uncommon for them to break. its recommended to replace both at the same time.
airboatgreg
2,866
3,114
Most likely the spring is gone. I think I have a couple if you cannot find them as a stand alone part
