Turn signals not flashing, intermittent problem
08Malibu
1,452
3,411
North Jersey
The turn signals on my 81 Malibu don’t flash when I first start the car, every so often. I’m thinking flasher, since all the bulbs work, and they start flashing after a bit. Opinions?
ELCAM
1,120
1,264
My guess is the alternator is not charging yet.
Do you have a volt gauge? If so what are the readings?
Sometimes my alternator takes its time to start charging.
Possible fixes.
Use a electronic flasher.
Change to a newer style alternator they are more efficient and have a higher output at a lower RPM.
ck80
Moderator
Moderator
5,744
9,120
When they don't work right do any of the lights work? Do any of the gauge idiot cluster light light up when they don't work?
Could be a flasher, could be an intermittent bad ground. The fact that it's every so often throws a wrench into things.
Any external/environmental factors in common when they don't work? IE a recent heavy rain,
08Malibu
1,452
3,411
North Jersey
No rhyme or reason as to when they don’t work. They illuminate, just don’t flash. My lights work. I have leds in the dash, but I don’t see how it would be intermittent because of that. I know that all the bulbs add up to the proper resistance to make them work.
ck80
Moderator
Moderator
5,744
9,120
Well, if you're of a lazy mindset it's about $4 for a replacement flasher from Napa, at least for one of my cars. I bought spares on a rock auto closeout even cheaper at one point.
So if your time means more to you than a cost of a beer it's a cheap swap, worst case you have a spare.
Next most likely culprit aside from a ground issue could be related to the stalk on the column, but, the fact it tells things to light just not blink makes me think that part is probably OK.
I've had bulbs that were dual filament based on what function that they served, idea being one filament served as the marker lamp and the second put out the blinker flash - think of nighttime driving, it's lit up but then flashes stronger when signaled right? Well, I've had one of the two filaments go out and lead to a blinker issue but the lamp still lit. Replaced the bulb and went back to normal.
Not sure if that helps at all.
08Malibu
1,452
3,411
North Jersey
The filament issue is a possibility. I did have that happen on my truck, only they sped up.
I’m just spitballing here. I haven’t even looked into the problem at all. As cheap as the part is, I hate throwing parts at a problem. Thanks
Cuse99
251
126
I had this problem and it was a bad ground wire on the bulb socket. The design sucks. I was able to diagnose this by pulling the socket out, with the bulb still in, and switching the turn signals on. I started to put pressure on the ground wire and the blinking lights were on. As soon as i let go of the socket, the blinking stopped.
It could also be a bad bulb. In previous posts there was some information on how to tell which bulbs were suspect.
