Ok I dont know if most of you guys are familiar with the remote mount turbos but if not just do some search on it. I know there are mixed feeling about it working or not working as efficiently like its suppose to but regardless of that they are proven to make numbers.
My idea is for a sbc motor preferrably the hated 305. Motor is pretty much built to stock specs with internals built to handle turbo and a cam a little bigger than stock.
My idea is to have a decent gas mileage vehicle with basically horsepower on demand. I read a build where they did a 302 or 305 supercharged and still got 20 something mpg and 500hp.
Anyway the system would be ran as normal but the catch would be in the exhaust. Im thinking about adding one of those electric exhaust cutouts. When it is open it would run through the regular exhaust(straight pipes) but when closed the exhaust would be running through the turbos.
My thinking is performance on demand with gas mileage. Also my turbos wouldnt be costantly running so I dont less to worry about as far as the oil pumps going out or the turbos getting messed up because they arent constantly spooling.
If i just went regular remote mount turbos and set the boost low then I would most likely have a problem with the turbos being more of a restriction than helping. This is where the electric exhaust cutout comes to play. Exhaust is not running through the turbos so the arent active. I flipped the switch and exhaust is routed to the turbos for beast mode and I got hp on demand and can boost it up knowing my engine can handle it. Flip it back for cruise mode. I know it would be a plumbing nightmare but the only extra plumbing would be for the regular exhaust when turbos arent active(not counting the turbo plumbing in that).
Heck the plumbing of a traditional turbo is a nightmare. Let me know what you think about this.
