on my 1988 monte ss i have installed UMI part # 3035 front 1 1/4" sway bar, tighten up the front end a bunch. 3044-275 UMI rear sway, this bar attachs to the bottom of the axel tube of the rear end, works great and easy to set up. using the UMI upper control arm #3056, this has the adustable rod ends, nice setup. 5 degree +caster, 1 degree neg camber, when i go to the track i align it to 2 degrees neg camber just by adding a couple shims to each side, when i am back on the street just take the shims out and i am back at 1 degree neg camber, easy and simple. ramey at UMI helped me a bunch
i am using a 1990 camaro center link shortened up 1", this link drops my tie rods parallel to the ground, and cut the bump steer to almost nothing. my idler and pitman arm are at 6 degree angles out, this added a little negitive ackermann. at 10 degree wheel turn i am at 0 toe, not the 4 degree toe out on the normal parallel steer. running a 1/8 degree toe out this car loves to go into a turn.
