We already went over the fan thing with OP. His thread on it is what pushed me to replace my flex fan with a fix blade/clutch setup. It's surprising how loud that flex fan was.Those mounts will mess up your fins in time. Better to go to the junkyard and pull a used V8 shroud from a G body. Oh and replace that flex fan with at least a clutch fan. With a serpentine setup you should be able t use a reverse rotation nylon fan from a Chevy truck.
Just swapped from a clutch fan...Those mounts will mess up your fins in time. Better to go to the junkyard and pull a used V8 shroud from a G body. Oh and replace that flex fan with at least a clutch fan. With a serpentine setup you should be able t use a reverse rotation nylon fan from a Chevy truck.
Yea I thought about that, but man, if I "F" it up, I'm F'd...If you still have the original shroud set-up, you could take that one in the posted image & merge the two together (cut the new piece up & pop-rivet the curved section to the existing shroud).
Or, use some metal from a local hardware store & try to do the same thing.
