Is this a daily? If so, I would NOT upsize the wheel cylinder. The rear brakes already are easy to lock up with the 3/4" bore wheel cylinder and a 7/8" bore wheel cylinder will make is more sensitive to premature lockup.
If this is a drag car, then MAYBE upsize the wheel cylinder, but only if you are having trouble foot braking at the starting line.
I would install the wheel cylinders brackets as the wheel cylinder do move when the brakes are applied. The wheel cylinder is supported by ONE bolt and it likes to pivot because there different amounts of pressure being applied to each side of the wheel cylinder. The brackets will also make the rear brakes more predictable because one side of the drum brakes lock up before the other because one of the wheel cylinders on one side pivot more than the other size. If you have someone apply the brakes, you can see the wheel cylinders move and each one will move a different amount. NOTE: Don't get run over while looking at the wheel cylinders move. This is most likely the most effective mod to do to your rear drum brakes to make them more predictable.
For drag racing, two long pads per side may help a little. I would only do this if you cant hold the car while foot braking at the line. Choose the brake shoe compound to fine tune your rear brakes. If you need more initial bite, then a organic compound would most likely be best, Semi Metallics usually have less bite and ceramics have the least amount of initial bite. Organics do better when cold and cannot handle sustained high temperatures, but for most cars, this isn't an issue. Semi Metallics handle the heat better than Organics and Ceramics handle heat the best. If you get to much premature lockup with organics, step up to a Semi Metallic, To much premature lockup with Semi Metallics, step up to a ceramic. This has been simplified, because all pads compounds are formulated differently between brands.
Also, there is the aluminum replacement drum. Cardone Part number 2c18000. I don't know if you can purchase these any longer. It looks as if they may be sold out.
Here are the specs.
