Upgraded master cylinder, crappy pedal now...
81_El_Homewrecker
170
Hey guys, so I took your advice and upgraded my master cylinder to the larger Blazer master. After bleeding everything and going for a drive the pedal is very hard, and I am not confident in a panic brake situation. I can slam on it and not lock up any of the wheels. I plugged by PCV to try and get a little more vacuum but it’s not a substantial improvement, barely noticeable. I currently have the stock dual diaphragm booster and am thinking about upgrading to the dual B-body booster. Has anyone done this upgrade and seen an improvement between boosters?
P.S. - Engine pulls 15” at idle, not sure what it’s pulling on the booster but the PCV is T’ed into the booster port on the carb.
Max Headroom
420
389
I did a stock replacement once and had the same problem. Turned out to be the rod inside the booster was the wrong length for the new booster. You might want to start there.
81_El_Homewrecker
170
I have the stock booster on there now, only replaced the master with the larger bore for my disc brakes. I’m thinking the larger dual diaphragm b-body booster might help out.
Max Headroom
420
389
I understand but the booster I replaced, which was called out for my vehicle, had a longer travel than my original. The rod fit but when I hit the breaks, it was like stepping on a rock. Turns out that I needed a rod about half inch longer. Don't remember how I found out but when I put the new rod in everything worked like it was supposed to. Just something to be aware of.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Do u have 4 wheel disc?
69hurstolds
8,196
17,598
You made sure you didn't trip the combination valve switch during bleeding, right? Sometimes, if this happens, the pedal gets hard as a rock and you only have 1/2 your brakes.
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
X 2 ^^
I've had this happen.
Had to let it sit overnight to re-set itself.
Guy
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
