I got time to try a mock up of the Pypes kit & down pipes to see what all I'll need to do with mods for the cats. The passenger side went together pretty nice with a little adjustment at the manifold. The drivers side didn't work at as easy, the down pipe didn't connect to the X pipe (some adjusting from the rear should help) & doesn't quite sit/seal with the manifold (has the cast in donut flange.) As I adjust it to work, the end of the pipe comes up & hits the crossmember. I know I have to cut the down pipes for the cats but I'm not sure to use a stainless flex pipe due to the limited amount of pipe in that area. Now if there is a gasket donut or something of the like the give me more adjustment play at the manifold & flange could give me some adjustment needed. Maybe the Pypes 30 degree pipe might even be close to make things fit. For a reference I was thinking of putting the cats in the openings of the crossmember as they fit in that spot.
