Can I use PCM outputs to provide signal to the stock gauge cluster to get the speedometer, tachometer, oil pressure and water temperature working?
My PSI conversions harness has wires for the following:
Black - Speedometer signal from PCM. 4000 pulse per mile signal that is readable by most aftermarket speedometers.
White - Tachometer signal from PCM.
Grey - ECT Lead, Engine Coolant Temp output wire from PCM.
Tan - Oil Pressure Lead, Oil Pressure output wire from PCM.
Brown - MIL Lamp Ground, provides a ground to the “Check Engine Light” bulb from PCM
It also has these wires which aren't hooked up:
Orange - Park Neutral Signal into PCM.
Purple - Brake Signal / TCC Ground. Signal into PCM so it knows when brakes are applied, to control Torque Converter Lockup and Cruise Control.
