V6 3.8 to 5.0 v8
3.8 to 5.0swap
13
Hello i swapped my v6 to a 5.0 v8 i have a question when removing the v6 wiring harness i had to cut 2 wires that ran to a sensor or plug on the side of the transmission now i cant find where they connect to on the v8 wiring harness your help is greatly appretiated thank you
Clone TIE Pilot
3,854
2,600
Galaxy far far away
You didn't need to cut anything, all wiring harnesses are easily removed. The plug on the side of the transmission is for the torque converter lockup solenoid.
3.8 to 5.0swap
13
The new harness dosent have that plug i checked it and it dosent seem like anything was cut from it
Clone TIE Pilot
3,854
2,600
Galaxy far far away
Are you sure its a G body harness? Could be a harness for a manual trans F body?
