VERY rough idle, hard start, getting worse need help
Myles
Jun 17, 2011
80
17
8
Hi guys,
81 Malibu 355sbc 11.89 @112
At the track, car started running rough, would backfire/ shoot gas out of carb when stalling.
Now the car is barley startable, will only start if I advance the timing all the way, runs like garbage, stalls, etc..
This misfire has evolved into almost not starting.
Iv tried:
-my new 750hp dp
-rebuilt 650hp dp
-2 hei stock distributors
-replaced intake manifold gaskets
-adjusted all my valve lash
Car keeps doing the same thing.
When we used to be able to keep it running the vacuum was around 10
Have you guys ever felt with this?
Did I get bad fuel? Slowly diluting my good fuel between warm up and then stalled after 1st burnout? Head gasket issue? Cheap jegs harmonic balacer, dont think its that cus can barley make it run at low rpm any. Its mark and hasnt slipped.
Starting to loose my mind!
Thank you
81 Malibu drag only
355ci stock dish piston
Cam is right lash solid
510 530 lift,
242 250@50
106lobe
64cc dart iron eagles
215cc runners (on a 355 lol)
Offenhouser intake
1" carb spacer
Holley 750hp mechanical
Stock hei
Electric water and fan
Th350
5000stall
4.56
28"slick
Bat and fuel cell in trunk
Please let me know what your think. Plugs are dark now due to trying to get it running 1000000 times
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you have started a few threads about this problem, stick to one so we don't get confused
Oct 14, 2008
8,823
7,774
Melville,Saskatchewan
MrSony
6,828
6,736
Des Moines, Iowa
Clone TIE Pilot
3,857
2,609
Galaxy far far away
Check for vacuum leaks.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
maybe he'll read your suggestion this time around....
Clone TIE Pilot
3,857
2,609
Galaxy far far away
He probably won't.
