Vi-King/PST Pro Touring Package
james@pst
GBodyForum Sponsor
Jul 31, 2012
137
Montville NJ
Not ready for coil-overs on all four corners? For you A & G body owners, we have paired our rear performance lowering springs with VI-KING® front coil-over conversion and rear smooth body shock kits to create a lowered, sleek pro-touring stance that competes with the best of them. Achieve top quality handling, cornering and control with PST.
Bolt-in conversions with no modifications of frame or spring pocket
Front coil-over kit replaces factory springs and shocks
Works with OEM stamped steel control arms or aftermarket tubular arms
Both front and rear shocks are double adjustable with 19 positions of compression and rebound
PST performance rear lowering springs have increased spring rate for superior handling and control without sacrificing ride quality
Springs are coated to protect from corrosion
http://www.p-s-t.com/s.nl/it.A/id.10115/.f?sc=12
james@pst
GBodyForum Sponsor
Thread starter
Jul 31, 2012
137
Montville NJ
The front springs in the coil over kit have a spring rate of 450lbs if you are running a small block and for the big blocks it is 550lbs and the rear springs have a spring rate of 135lbs
Thanks
James
G-Body Performance Upgrades
