So when i use the blinkers the needle on the volts guage will bounce. When using headlights the needle drops to 12 on the gauge and stays. The wire from battery to alt is new. 10ga. New alt 2wire plug. The ground cable from battery to block is new. Power cable from battery to starter is new. Alternator tested good. What else can i do to stop the bouncing? Or is this kinda normal on older cars?
