Sorry for the late response, been busy over the past couple of days. There is a thread in the wagon section on this site, from a guy who is building what he calls an IROC Malibu wagon. He posted some information and photos regarding clutch linkage and bellhousings which you may find helpful. I'm in the process of gathering up parts for a similiar project that I have here. I have an '81 Iraqi Malibu with the 229 and 3 speed Saginaw, and I'd like to replace the 229 with a mildly built up carbed 4.3, and swap the 3 speed out for a T5. Just something a little different. A bit zippier than the 229, and a bit easier on fuel than a V8. As far as I know, if you want the shifter on the T5 to come out close to the original 3 speed shifter, then you need to get a T5 from a mid to late '80s S10 with either the 4 cylinder or the V6. The S10 T5s had the shifter mounted further forward than the Camaro or Firebird T5 trannys. I haven't actually made any measurements, or tried to install the transmission yet, so I don't know if this is a sure thing or not. I have an S10 T5 here, and I know that it will bolt up to the bellhousing, but as I said before, the input shaft may have to be trimmed, or the transmission spaced away from the bellhousing, in order for everything to fit together properly. I know I looked at a site for a company that manufactures a spacer that goes between the transmission and bellhousing, so that the input shaft doesn't have to be trimmed. If you go with a T5 from a Camaro or Firebird that was originally a V8 car, then it should bolt up to the bellhousing and the engine OK, but the shifter is further back. Or you could get both the Camaro V8 T5, and the S10 T5, and try swapping the S10 T5 tailshaft housing onto the Camaro T5, but that's alot of work on a fairly simple project. I'll see if I can find the name of the company that manufactures the spacer. Sorry for the long post.
