PONTIAC Wagon rear wheel tub rust
1983GrandLemon
10
11
Hello fellow wagoneers!
I bought this big blue turkey last year and am finally starting to do something with it. The rear inner wheel tubs are a tad crusty, mainly the passenger side (drivers is easy fix).
What i could find on the interweb is the car is essentially the same as a 2dr malibu from about the middle of the car going forward (which is great cus i got a big gaping hole where my feet are supposed to be). What i need is answers/pictures/parts links/advice to any possible repair panels i can use to fix the rear inners. Are the 2dr gbody inners close enough to make work?
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Cut it out and build new. Or just mini-tub it now. Because there is no easy way out...
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
The floor pans are universal between the G-body cars. The areas that you show don't look like a bad fix at all. I don't know how your welding and fabricating skills are, but it pretty much entails cutting out the rusty metal and welding in a few patches. Hows the rest of the car rust-wise? How are the rear frame rails for example?
1983GrandLemon
10
11
Oh i'm no stranger to fab work haha I'm a welder by trade.
As for the rest of the car, the rust isn't bad. Passenger side floor is good, frame rails are good (only reason i bought the car), the doors aren't great but not bad. Only because I'm lazy and rather particular I want to weld in proper wheel inners. Heres a pic of my yaba-daba-doo drivers floor
1983GrandLemon
10
11
Hmm haven't looked into doing a mini tub, mostly because i want to put the interior back together. Do you know of any good build threads that have done something similar?
motorheadmike
8,976
27,522
Just one.
Reactions: 4 users
85442/86buick
746
1,118
Perth Country , Ontario
I am sure you can buy report inner and outer wheel wells.....thinking Goodmark makes them .
mikeselky85
Jul 29, 2009
55
62
You can look at my build thread, I’m currently going through the process of fixing the same issue, all of what you would need to replace is not made new/ aftermarket for these cars in the back. Just a heads up
1983GrandLemon
10
11
Yes unfortunately I have figured that out...i thought the regular malibu inner tubs would be close enough, but no.
I recently purchased a new drivers side floor section, haven't got around to putting in
