Hey guys:
I am reviving an '83 Cutlass Cruiser(was a board member's car here actually) with the 231.
It's running good other than some minor carb issues, but something electrical happened all of a sudden..and this gets weird:
When i first got it running after sitting a couple years, I noticed the Charge lamp was on dimly. I went for a couple test drives and when I got back from those both the OIL and CHARGE lamps were on full strength. I turned the engine off, turned the key back to ON and both the OIL and CHARGE lamps were off, even with the key on. I started the engine, and the OIL lamp came on bright and went out when the engine stalled.
I swear I'm not making that up.
I had a suspicion, so I got the engine to idle and pulled the negative cable and sure enough, the engine died. I know these alternators have to have the light to excite the regulator, so I'm wondering if I have a wiring problem and not an alternator problem, since now the charge light is totally unresponsive.
Just not sure why the oil light is working in reverse during all this.
Anyone ever have these kind of gremlins?
