Ok guys so got everything good to go on my motor and my brand new edelbrock long water pump leaks at the back plate after I bled the cooling system. So I drain the system pull the pump, pull plate and clean all surfaces. I install a new feltlpro to gasket with a small amount of permatex #1 form-a-gasket. Let it dry all day. Re bled cooling system and sup rise it leaks again
So my question is how the hell do I fix this issue?
I have a can of permatex right stuff. Was debating pulling up part tomorrow cleaning it all up laying a good bead down and installing the plate with no gasket.
