Good advice... It is new, I bought it for a '84 Monte Carlo...I think that the plug is 1/2" pipe thread.
Is that a new water pump? If so did you get it for the 84 Monte Carlo which is clock wise rotation? Or did you get it for a later car which is counter clockwise rotation for the serpentine belt system?
I think you want the 252-719 it is reverse rotation.
ACDELCO 252595 Specifications | |
Casting Number | 81-18308C |
Fan Clutch Included | No |
Housing Material | Grey Iron |
Hub Height | 175.76 |
Hub Height (IN) | 6.925 |
Hub Hole Quantity | 4 |
Hub Hole Thread Diameter (IN) | 0.3125 |
Impeller Material | Steel |
Impeller Rotation | Standard |
Impeller Vane Quantity | 6 |
Includes Back Housing | No |
Mounting Hardware Included | No |
Mounting Hole Quantity | 4 |
Outlet Quantity | 2 |
Pulley Included? | No |
Remanufactured? | No |
Thermostat And Housing Included? | No |
ACDELCO 252719 Specifications | |
Casting Number | 626C |
Impeller Rotation | Reverse |
I see, 7" in height... Long water pump... Thank you 👍🏾
ACDELCO 252595 Specifications Casting Number 81-18308C Fan Clutch Included No Housing Material Grey Iron Hub Height 175.76 Hub Height (IN) 6.925 Hub Hole Quantity 4 Hub Hole Thread Diameter (IN) 0.3125 Impeller Material Steel Impeller Rotation Standard Impeller Vane Quantity 6 Includes Back Housing No Mounting Hardware Included No Mounting Hole Quantity 4 Outlet Quantity 2 Pulley Included? No Remanufactured? No Thermostat And Housing Included? No
ACDELCO 252719 Specifications Casting Number 626C Fan Clutch Included No Housing Material Grey Iron Hub Height 175.76 Hub Height (IN) 6.925 Hub Hole Quantity 4 Impeller Material Steel Impeller Rotation Reverse Impeller Vane Quantity 6 Includes Back Housing No Mounting Hardware Included No Mounting Hole Quantity 4 Outlet Quantity 2 Pulley Included? No Remanufactured? No Thermostat And Housing Included? No
Same specs just different rotation.
