WC T-5 question
1evilregal
3,056
4,357
Greensboro, NC
guys, I'm a bit confused, and those that know these transmissions may have an answer for me.
I've picked up a couple of these over the last year or so, both out of v-6 cars, and picked up a couple of bellhousings out of v-8 cars. I went to mount the trans on bellhousing a couple days ago, and the patterns don't match up...
the bell housings both are part # 14075723, and several fleabay listings show they are for the t-5 v8 application. do the v6 equipped T-5's have a different body where it mounts tho the bellhousing, or am I missing something?
Thanks in advance,
Darin
dr78442
731
912
massapequa park NY
Sorry. The V6 transmission use a different bolt pattern.( A Ford pattern I believe ) You will have to find an 8 cylinder transmission to bolt up to your bell house.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
The input shaft of the V6 WC is longer than the V8 version as well. You can make a 1/2" adapter plate to solve both problems
  • Informative
1evilregal
3,056
4,357
Greensboro, NC
thanks for the quick replies! GP, that's an interesting idea... will have to look into possibly making something like that...
1evilregal
3,056
4,357
Greensboro, NC
do you guys know if all the internals are the same (bearing sizes,etc...)? maybe pick up a main case and swap the internals and input shaft?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the rebuild kits for the WC are the same for the GM and Ford 1985 and up versions.I thik I have a WC V8 main housing hanging around someplace but the shipping would be a killer.
1evilregal
3,056
4,357
Greensboro, NC
both mine are 94 and 95. thanks for the offer, but think you're right. could maybe find one cheaper than the cost of shipping and possible fees...
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
this may help...a munci bellhousing will make the transmission sit straight instead of the 17 degree angle. The muncie bell housing has no bracket for the slave cylinder so I run the Mcleod throw out bearing
pagrunt
9,128
15,258
Elderton, Pa
Wouldn't an early C4 hydro clutch bellhousing work? Thought they had a slave cylinder mount on them. I'd even suggest a'85-'87 square body 6 cylinder if they used the 153 tooth fly wheel or the V8 with the 168 tooth flywheel.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
that is an interesting question, there is adapter brackets that I could have used or fabricated my own to use the slave cylinder but I opted to go with a hydraulic throw out bearing
