Weather strip problem
Doug Chahoy
2,550
I’m installing the window stripping on my El Camino. I bought the complete Metro kit from Ecklers. When I installed the door stripping, the doors are tough to close. Now I’ve installed the drivers roof/window stripping and not only does the door not want to close without a hard slam, the window at the B pillar doesn’t even seal. And suggestions on any adjustments or did I get typical aftermarket garbage?
565bbchevy
8,438
Michigan
For my Monte I originally bought Soffseal and they fit like crap so I sent them back and bought Metro which were better fitting but still required some adjustment to get the door to shut perfectly.
That being said I have heard good things about Steele Rubber Products
Doug Chahoy
Thread starter
Nov 21, 2016
2,550
Thanx, I’ll check them out. This aftermarket CRAP is such a PITA
303'505rollin
520
Colorado2newmexico
I know there not mine but would heating them up with a high temp heat gun and some big flat lipped welding clamps to break them in per say. Not too much to burn them but to soften them. I dont know how they were new as mine were already broken in and were good or never had it long enough to change them out
Doug Chahoy
Thread starter
Nov 21, 2016
2,550
I ordered the Steele stripping. I’m not going to risk damaging the Metro’s. Now I’ll fight it out with Ecklers.
Doug Chahoy
Thread starter
Nov 21, 2016
2,550
Got and installed the Steele stripping. Installed easier. The first few times closing the door all the way took alot of hard pushing. Left them sit closed for 3 days and they’re closing MUCH EASIER
G-Body Performance Upgrades
