1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Weather Stripping and New Lights
Discussion in 'Electrical' started by Thugnificent, Oct 21, 2017.
  1. Thugnificent
    Thugnificent Not-quite-so-new-guy
    Aug 9, 2017
    16
    6
    Few things I'd like to fix on my car
    Both doors need weather stripping, I'm going to buy Metro, is the installation easy? Is there a guide?
    Also, at night I cannot see at all, the speedometer, etc. Is there a light supposed to be there? If so, how do I install new ones?
    Also, my high beams are out, what bulbs would you all reccommend?
    Sent from my SM-G955W using Tapatalk
  2. Dixie Restoration Depot
    Supporting Vendor Silver
    Oct 24, 2016
    62
    121
    33
    Manchester, CT
    Which weatherstrips would you be replacing? If all of them, here is a link to a YouTube video showing how to install the window felts:
    The door weatherstrip is just a remove and replace. As far as the hardtop seal goes, there are numerous ways to remove them. I personally just use a plastic pry tool that fits the channel and that has worked well for me. On the install, I tend to dry fit everything and then slowly remove and apply adhesive in sections. If you have trouble, a small amount of dawn dish soap and water will help it slide into place.
    Something to remember: the door glass will almost always need to be readjusted after a new set of seals and there is a "break-in period" where the seals are shaping to your door glass.
    With regard to the lights at night, there are bulbs behind your gauges. I have swapped my personal car and our shop car over to LED bulbs which are much brighter, but you lose the option to dim them.
    • Informative Informative x 2
  3. CaliWagon83
    CaliWagon83 G-Body Guru
    Silver
    Nov 12, 2017
    720
    259
    Orange County, CA
    Do you offer weatherstripping for 4-door/wagon models?
  4. Dixie Restoration Depot
    Oct 24, 2016
    62
    121
    33
    Manchester, CT
    Yes, we do. feel free to message us if you have any questions I don't want to hijack someone's thread.
    • Like Like x 3
  5. mclellan83
    mclellan83 Greasemonkey
    Jun 27, 2017
    243
    99
    Pgh, PA
    As far as headlights go, I cannot recommend LED's enough. I never even have to use the highs on my units since I get more than enough light from them and they were very cheap. I bought a cheap set from Amazon because the ones I ordered from Ebay ended up only being a single one that I could not get to work, turned out all I had to do was repin the headlights to get them to work correctly. I have pics of them running but they are so bright that the camera goes nuts
  6. Thugnificent
    Aug 9, 2017
    16
    6
    Any specific LED from Amazon you'd reccommend?
  7. mclellan83
    Jun 27, 2017
    243
    99
    Pgh, PA
  8. Flyers9928
    Flyers9928 Greasemonkey
    Jul 30, 2014
    200
    31
    Pottstown Pa
    Did you just replace the low beams? or did you replace all 4?
    How did you wire them ?
  9. mclellan83
    Jun 27, 2017
    243
    99
    Pgh, PA
    I redid all the lighting in the front of the Monte, I used these as the lows and only use them as that. I can kick them up to high and then see absolutely everything with just them. I hooked up a semi halo set on the inner 4x6 but the HIDs broke during the install so have just been running these because I see more than enough with them.
  10. pontiacgp
    pontiacgp Canadian Prime Minister
    Mar 31, 2006
    21,012
    2,662
    Kitchener, Ontario
    I run two bi-xenon on the outside and two hid on the inside hi beam with 4 Hella conversion lens. The HID are brighter then the LED and they last longer than the LED. The other advantage to the hid is they create heat to melt the snow on the lens. The LED create lots of heat but only in the circuit board so if the integrated fan stops working the LED burns out real quick. LED's are suppose to last a long time but to get the quality LED you'll be paying alot more than what you'll pay for the cheap chinese lights. Most of the LED's on the market are poor quality and will burn out alot sooner than advertised.
    • Agree Agree x 1
Loading...
Similar Threads - Weather Stripping Lights Forum Date
Wind blows in at speed after replacing weather stripping Electrical Jul 11, 2016
Changed weatherstripping, doors shut hard, HELP! Electrical Jul 11, 2016
Clicking noises, Dry Weather strip., and Other 1980 Malibu Questions!! Electrical Oct 26, 2015
Regluing headliner, weather Electrical Jun 18, 2008
Share This Page
