weather stripping
JD1964
374
506
Is the weather stripping similar on the two and four door models? I know the lengths will be different but if I find decent weather stripping on a two door model, could I cut the length down and use it on a four door model? Or do I need to get stripping from a four door? Need door weather stripping for a 79 Malibu wagon. On a limited budget so that's why I'm looking for donor cars in the junkyards
85ss/85gn
285
252
beaver dam,wi
They make aftermarket wagon door weatherstripping
Doug Chahoy
2,565
2,662
If you don’t care about a seam somewhere, use it to be frugal. The ends at the A&B pillars need to be there. If you buy A/M stay clear of Metro, my doors didn’t want to close.
Ribbedroof
4,887
6,924
Wellston, OK
The soffseal for wagons is poor. First set was made wrong, second was closer, but rear door broke after about 6 months, and the fronts never sealed at the rear edge.
I'll try the hard to close Metro over the junky Soffseal next time around
Doug Chahoy
2,565
2,662
I just installed Steele, MUCH BETTER
Ribbedroof
4,887
6,924
Wellston, OK
Damn. At $325+ for a wagon set, they better be OE quality.
Probably don't sell many for sedans or wagons, until the buyers have learned the hard way about other brands
  • Wow
oldsmobile joe
2,067
3,053
mpls
Simple answer, NO. Two doors are frameless around the glass and are two pieces. 4 doors have a frame around the glass and are one piece.
Hard closing door are normal with new seals. The rubber hasn't settled yet. Give it time. Even new new factory seals have this condition. Its what we call normal.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,173
9,769
Gainesville, Fl
I would hold out and budget for a new set of weather stripping. It's a crapshoot whether you're going to find decent weather stripping at the junkyard.
As was mentioned, you can't use 2-dr door seals. front 4-dr sedan seals are the same, but the rear seals are different.
I am using metro seals in my wagon and I like them. I suppose everyone has a different experience and preference.
JD1964
374
506
Thanks for the replies. I still have most of the pieces but they are falling off and kinked in a few spots. I'm gonna try and fix it up and glue it back with 3m weather strip adhesive. Maybe I'll try and bolster weak areas with some universal D shaped stripping. While the engine was out we also made efforts to seal up leaking heater box in the firewall area. This car normally sits out in the weather and we're getting tired of conducting mold factory experiments. Front floor boards are in bad shape too and I need to patch in some sheet metal and seal it up.
