Hey guys. I posted in the New Members area a month ago about a 1980 Malibu I was given. I plan to expiriment with carbureted turbo system on this engine, and still am at the planning stages. Wanted to see if the engine was functional. It has a Chevy 229 V6. It appears to be built just like a small block.
Made a resurrection from the weed patch last week, if you want to hear it run, here are the videos!
At first I was told the car hadn't run since 87, but I have since learned it may have been 97. But that is still 12 years of sitting!
I externally cleaned the carburetor with Berryman B12 spray, then filled the carb bowl with same spray via the bowl vent. Changed the oil, installed a starter and battery, and this is the result:
http://www.youtube.com/watch?v=xGXOQK6IXDg
Then I found a radiator and ran it for an hour or so, here is the second run:
http://www.youtube.com/watch?v=8Zcoo2eXAgI
Hope you enjoyed seeing that resurrection from the weed patch! 🙂
Will keep posting as I work on it.
Later,
David
Later,
David
