After I run my car the battery is drained and can't turn over the starter. The battery is a 2 2/2 years old. I recharged the battery with a big charger and got the car started. Performed a load test on it and it is on the weak side of the scale. While the engine was running I also used the load tester on the charging system and it checked out. Shut the motor off, after 5 minutes went to restart it and the battery was too low again. Guess the battery isn't holding a charge anymore? Car wasn't running too well either which failing batteries can cause.
