So I was adjusting timing today and using it to set my rpm after overhauling my carb (an edelbrock 750 performer w/ electric choke) and I noticed that after playing with the throttle that the rpm wouldn't return back to my 850 it would stay at like 1100. Checked the cable and its loose. Checked with vacuum gauge and vac is normal. Sprayed around all intake areas for vac leaks with carb clean and no changes. Pressed on linkage and idle dropped back down. Raised rpm and it stuck again until I pressed linkage. Then the rpm went all erratic and it died. Now it won't restart. Checked for spark good. Made sure it still had gas (no gauge) good. This ones got me stumped! Help please! Engine is a semi built sbc 355.
