hello all i am mounting my body on the frame and at the rear the back 4 mounts in the trunk are being odd so there is 4 holes and i am using new mounts and one hole touches other does not then it is opposite on the other side. can i use shims and long bolts or will that cause driving issues. the two that are touch are diagonal to each other then the two that are not touching are the same
