I put my wiring harness in the car and got my gauges, etc wired up. Finally put a battery to it and I have power but my gauge lights and running lights are on as soon as I connect the battery. Doesn't matter what position the headlight switch is in. When I turn the key to "ON" the gauge lights get brighter. No matter what as soon as the battery is connected I have power to things I shouldn't until I turn the key or turn the headlight switch on.
The power for the gauges is coming off the gauge fuse and I also tried a number of other locations that should be key on but no change. I have the battery positive going to the "B" terminal as well as the positive lead for the fuse box. The smaller lead is on the "S" terminal. Ground is to the frame and there isn't an alternator on it yet. Starter works fine. I turn the key and it kicks on and off like it should. No headlights or taillights are in it. Just the license plate lights and rear marker lights. Its like the ignition switch is stuck on or something. This is the complete harness from my 83. All I did was cut off and tape up the circuits I didn't need.
Any ideas???
Any ideas???
