So I have a 84 cutlass, 489bbc aluminum heads. 90/10 shocks up front,qa1s in the rear, 7 clicks left 14 clicks right, 170lbs springs, by springs up front. F41 sway bars front and rear, full cm 12pt cage, boxed frame, 275 drag radials, 2 step at 3000rpm,3500 tsi convertor,th400 w brake,9 inch ford rear w3.70s spooled,umi control arms in rear. My problem is when launching the left front tire is up 14-18 inches and the right front is just touching the ground. How the heck is that possible with full cage and boxed frame???? Am I that far off with suspension? Any help would be great
