Here is something other than our usual suspension tech help for you guys to chat about.
Naturally aspirated street build.
So you found a 6.0 and 4L80 for free like the story goes.
You ask yourself... "What is the cost when done?"
After reading online you find you need a decent cam, (one of our favorites .585", 228-/230-degree duration split, and 112-degree LSA). <--- Great for the street btw.
Maybe some mildly worked 243 heads and some valve springs to round the power up a bit.
Installation accessories, motor mounts, oil pan, exhaust, front engine accessories brackets and all associated seals and gaskets.
Maybe an aftermarket fuel management system, injectors, trans controller, radiator and fans.
All this for roughly 520 hp at 6,000 rpm and 500 lb-ft of torque at 4,600 rpm.
Again...What is the cost when done?
For reference...
a well thought out street SBC 383 will make roughly 495 hp at 6,000 rpm and 495 lb-ft of torque at 4,500 rpm.
a well thought out street Mopar 383 will make roughly 530 hp at 6,000 rpm and 520 lb-ft of torque at 4,500 rpm.
a well thought out street Ford 351W will make roughly 490 hp at 6,500 rpm and 470 lb-ft of torque at 4,500 rpm.
For reference...
