Okay. Do appreciate the pictures. What my ride came with was what you call the checkerboard 14's and since the vin tag says it was built in Arlington, Texas, calling them "Mexican" sort of makes sense. The other set in the picture I do recall, only they were on an El Camino and the owner claimed they came as a part number for a Camaro. His back story was that he had to order them special to get the correct back set to fit the Elky's wheel wells. Not sure now if my range of 2-3 hundred for the set in question is correct. Being only a two year model, they might go higher at maybe 3-4 hundred, again depending on the finish. Buffed and polished and devoid of scratches and dings would certainly fetch a higher price, as would selling them up in the rust belt as opposed to vending below the Mason-Dixon line where road salt is not so common. If I had a budget for baubles and trinkets I'd be inclined to give them some consideration but money is tight right now, (like ain't it always) and my Malibu steelies will do the job just fine for now.
