What are you guys doing for vapor barriers?
6,001
12,685
What are you guys doing for vapor barriers inside the doors? I have my original paper vapor barriers, but they aren't in the greatest of shape and probably weren't the best to begin with. I was thinking if getting some 2 mil plastic (I may even have some) from home Depot and using the paper barriers as a template to cut out some new ones from the plastic. I'm not sure what the best way to attach them would be? I could use a spray adhesive and stick them on, or just use some type of tape and attach them that way. What has everyone else done?
565bbchevy
9,611
12,668
Michigan
The strip caulk works well for plastic or paper and since it stays pliable it is easy to remove your vapor barrier for access in the door if needed and you can just push it back on when you are done.
69hurstolds
8,185
17,567
And yeah, the strip caulk is how it is done like it should have been to begin with. But they also augmented it with that black paper tape crap that dried up normally. :)
79 USA 1
1,063
2,036
Cheektowaga, New York
I've used clear Mylar that I picked up at a local fabric store, Wally world (Sorry....Walmart) may also have it in their craft and fabric area. The strip calk is the way to go.....Home Depot should have it with their household air conditioning and sealing products.
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Bubble gum and garbage bags.
  • Dislike
6,001
12,685
I have plenty of strip caulk. The classic industries ones are nice but $25 is a little steep for a couple sheets of plastic, a whole roll at HD is only like $15. I think I can reuse my jute padding. I gotta go to the auto body supply place and get some amber rustproofing to spray inside the doors first before I put the panels on.
