REGAL What backspacing do I need
Greekfreak5757
6
I have a 85 Buick Regal and I wanna put a 15x10 rim in the back I have the frame notched out and am wondering what backspacing I would need
scoti
1,975
3,397
Texas
If you have a current wheel that fits, use it to measure your specific set-up.
Get the back-spacing dimensions from a known wheel/tire combo (even a narrower combo works to have a starting point). With it in place, use a tape measure & straight edges to do some measuring. Use the dimensions of the smaller combo w/the measurements to calculate what's optimum for your specific set-up vs. what 'Joe' has.
lilbowtie
3,460
3,965
Canton Mi
You can to it mathematically but you need to know what tire your going to use to get the section width to figure in.
scoti
1,975
3,397
Texas
Very true.
If you use a known/current/on-hand combo, you'll know which way the fudge factor needs to lean when doing the math calcs.
39F
530
602
Pittsburgh PA
My 82 has 15x10s 4.5 BS with 28/10.5/15s ,if you notch it they will fit 15x10 with 5.5 BS for the tucked look which I'm getting ready to obtain
Greekfreak5757
6
Ya I have 28x10.5-15 slicks am just wondering what backspacing I should use
Greekfreak5757
6
I have a 28x10.5-15 slick on my car right now with a 15x8 rim with center offset but I want that filled wheel well look
Greekfreak5757
6
I want the slick to be flush with the lip of the fender so I assume I should get a 15x10 rim with 4.5 backspacing correct
