Good story.
Back when I had to pull the AC box out of the firewall to slip the new seal in I accidentally broke the two plastic vacuum lines off at the grommet. Snapped them off clean.
Last week I went to the one junk yard that still has a few G bodies that Ive been picking parts off of. I checked the all of them before I found the single car that still had that harness left intact. Downside was the car still had the inner fenders and I had to fight with the thing to get the harness out in one piece. Took every bolt out and it still wouldnt drop enough so I stuck a bar in between to make just enough room to gently get it out.
I spent an hour or two over the weekend cleaning up the wires. The 4 wire connector for the feed was melted so I took it apart and put on all new terminals. I had an extra plug. Retaped the wires. Got it all ready.
Today I pulled the other harness with the broken tubes out. Easy job right ?
After I got them out I found the ends of the lines that are under the dash are way bigger than the originals. They wont fit. Too loose on the actuators. WTH ???????
Now what should I do ? New actuators ? Find another harness ? Think any other GM models might have the same one ? Cant take the plastic lines out of the ends. What a pain in the butt.
