melloelky
3,770
mass
attemped to grease the 8 zerks in the rear and one the upper control arms wouldn't take it.fought the arm out and of course on the bench it went fine..i changed both uppers to 90 degree fittings so we'll se down the road if anything's diffrent next time. i have @least 18 up front and an oil change later.
CopperNick
Thread starter
Feb 20, 2018
2,236
Canada
I am not sure why he would install solid mounts on what appears to be a mild SBC instead of the stock clamshell style but it looks like a mismatch between upper and lowers they shouldn't be squished closed like that when mounted.
Back a page or so ago, I did also happen to comment on that picture and mount, wondering why it looked deformed? It's location is the driver's side. Nick
Northernregal
Sloppy McRodbender
3,298
Red Deer, Northern Montana territory
I've been thinking about it. I need to look into a body bushing kit, I think a couple may be shot
I've used Energy suspension and the summit brand. Identical other than Energy suspension having better instructions.
Built6spdMCSS
2,187
Florida Beach
Nice. It's going to be one of them winter projects
565bbchevy
9,199
Michigan
CopperNick
Thread starter
Feb 20, 2018
2,236
Canada
So just a bit of time lag here as these were taken today but the work actually occurred yesterday.
This is the new/replacement inner door shell, aka, inner door skin?? that I elected to complete the rework on and then install. As can be seen, the rear edge of the skin follows the curve of the body more closely than its predecessor. There is still some deviation but that can be taken out once the door is loaded and reskinned. Some time whenever................
Because the ex-door did close quite well once I adjusted the hinge/door relation a little, that is the starting point I have selected for the new door alignment. To ensure I can get back to that as a starting point if I take the hinges off to strip and repair the A Pillar, I used a 1/8th drill bit and created two alignment holes in both halves of the hinge. They go all the way through the hinge and into the pillar. I use 1/8th transfer punches as my alignment pins.
And for those who love to drool over the carnage, here are a couple of detail shots of the lower door sill flange in all its rusty nastiness. The thing to understand here is that although this looks terminal, there is enough potential under the rusticles that it can be salvaged. The worst area is actually the lower lip of the flange, mostly because it is so mis-shaped and warped. To a degree, this situation was deliberate; the original repairs were done as a field expedient exercise just to re-attach the outer skin to the shell and both regain structural integrity and deny access to the elements, rain, salt, et al. No attempt beyond cutting away the most severely damaged and decayed segments was made to address the majority of the internal rust. To properly do so would have meant dolng what I just did, and there was not budget, time, or place to do it all properly, plus I did not have the tools or replacement parts that would have been needed. It took a very long time to accumulate it all plus then construct a proper shop/garage in which to put it.
So, ask me if I am having "FUN" yet?? You might just be surprised at the answer!
CopperNick
Thread starter
Feb 20, 2018
2,236
Canada
Took a run at the rusticles with an air saw and my 4.5 DeWalt. Got about half way there and started looking for some narrow width sheet metal. The flange is sort of okay at the ends but the curve in the middle apparently got mis-shaped at some point and is beyond reshaping. To get the curve put back in properly, the existing lower flange stump has to get cut away. From de-skinning the door, I actually have a thin section that is a bit too wide so it can be trimmed and about the right length so it may get a wee little bit of a shave to get its edges parallel then ????
81gutlass
24
I took the frame off the body to start a full restoration!
Classic Truck Consoles Dixie Restoration Depot Mike's Montes UMI Performance
