6door74
25
41
13
Maryland
You probably only need a half inch spacer, but I dought your studs will be long enough to work. I have 17×8 on the back of my car with 5 inches of back spacing. I run a inch and a half adapters, but my fenders are shaped different than yours.
I was actually thinking about ordering 1" adapters because i was worried about the stud length.
Turbo Zach
2,534
5,874
You need to measure your studs. That's why I went with inch and a half, or you will have to cut your studs down. You can buy longer studs pretty easily too, but then you might need different lug nuts. Best of luck .
wonderboy24
1,322
1,300
Davenport, Iowa
finally got the correct wire to put a light in the console . i went with a blue light to match the interior lights i have installed.my car was a column shift car.the guy i got the console from didnt give me the wiring for it.
Reactions: 6 users
RegalBegal
705
747
Goldsboro, NC
Took my tail lights apart and installed my Digi-Tails. Also, swapped my HID headlights for LED. ;)
MrSony
6,826
6,731
Des Moines, Iowa
Last night on a whim me and a buddy drove to Omaha in the Regal (4.5 hour round trip) and picked up a set of T Type wheels with some vintage Goodyear Eagle STs. In this instance, I use the word vintage as a synonym for shitty. They hold air and drive well enough, but damn they don't grip for nothin. Anywho, that was $300 well spent. And I found out my car gets about 17.5 MPG highway. 10 city, 17.5 highway. lol.
  • Winner
Reactions: 5 users
Ribbedroof
4,892
6,945
Wellston, OK
Put these on today but the rear is hitting the frame. They're 18x8.5 with a backspacing of 5.15. The offset is 10 as opposed to the front which is -6. I got the rears on Craigslist but the front is the correct fit because i ordered them new. They have 245/40/18 tires. What size spacer would i need to clear the frame?
Also, the tire place i had mount the tires put the interior side on the outside for 1 of the tires. I didn't realize till i took them out today. Is it absolutely necessary to get that corrected to the right side?
View attachment 85075 View attachment 85076
Why not put the deep backspace on the front, they should fit, and the -6 should come close to clearing the frame on the rear. I'm not a fan of spacers. I think worst case you could get away with the thin steel spacers such as those used on the 80s/90s 1LE Camaros
Wagons and ElCos are slightly different in the frame profile, but I had an 83 Bonneville wagon with 4.5" backspace and a 245 that cleared fine....the car also had a 5" backspace on the other 3 (bought it that way, not my doing) which were fine on the front, and just cleared the rear after I moved it to the other side (rear axle poorly centered...which is common).
If the tires are directional or have asymmetrical tread, I would have them correct the one that is on wrong
Ribbedroof
4,892
6,945
Wellston, OK
Last night on a whim me and a buddy drove to Omaha in the Regal (4.5 hour round trip) and picked up a set of T Type wheels with some vintage Goodyear Eagle STs. In this instance, I use the word vintage as a synonym for shitty. They hold air and drive well, but damn they don't grip for nothin. Anywho, that was $300 well spent. And I found out my car gets about 17.5 MPG highway. 10 city, 17.5 highway. lol.
I like 'em!
I remember buying a set of Eagle STs......in 1984 . Dude, you need to get those off of there
MrSony
6,826
6,731
Des Moines, Iowa
I like 'em!
I mean, for being probably 30+ years old they look "fine", but yeah. They have to go. I put em on there to take the picture. I still gots my steelies.
MrSony
6,826
6,731
Des Moines, Iowa
And they are tall as HELL. 225/70s. 27.4 inches tall. Dayum. The 235/60/15s I will be running are 1.3 inches shorter.
