Wageslave
1,749
3,338
I put in AC Delco R44LTS6 spark plugs. They are correct for a '96 Silverado and have 17.25mm of thread reach.
I had AC Delco CR43TS plugs in it which were correct for TBI heads, but the thread reach on them is 10.95mm.
Not a world ending difference, but it does add an extra 2 cc of combustion chamber volume.
Rktpwrd
Builder of Cool Shjt
4,166
23,915
Calgary, Alberta, Canada
Thanks for the info.
I’ll be checking mine now and replacing them as well if they aren’t the right ones.
SoFloG
1,107
1,258
South Florida
Washed her
Reactions: 5 users
Clone TIE Pilot
3,854
2,600
Galaxy far far away
Found I had a vacuum leak at the carb mounting gasket which is a thick AC Delco one. Retorqued it while hot seemed to fix it.
Local Hero
729
1,916
Northcoast, Cleveland, Ohio
Bypassed the heater core and started ripping out what was left of the original HVAC system. The case pretty much disintegrated in my hands. Will begin installing the Vintage Air heater and defroster tomorrow.
Reactions: 4 users
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
PICS!!!!!! of unit and install process plzzzzzz
Wageslave
1,749
3,338
Bought some turbo mufflers that I did not end up using and got half of my exhaust hooked up to the original exhaust system. I need to get a hole saw and an extension pipe to connect the other side. I won't say it will be show quality when it is done, but at least I can drive it.
mclellan83
4,245
9,422
Pgh, PA
My buddy is ripping right through it, got the digital air ride going together and while the rear axle is out might just do the C6 Z06 brakes as well since the vinyls should be in today
Reactions: 8 users
RG383Hurst
48
134
33
321A22C4-DFB6-4D75-B1FB-CAA056BD7056.jpeg D1DBE32F-C8BF-41CB-9DCE-6BCDE1E6C309.jpeg 687DF348-8ADC-4F4E-9AB5-62270688E574.jpeg 9AF71F15-F95F-43FB-BE13-F37AC41D0BF6.jpeg 7F79E0DA-9080-42D6-9A11-3585808B67D3.jpeg I was able to remove the old all metal rear bumper and install the new aluminum/fiberglass rear bumper set up. Also installed the lighter bumper brackets. Weight savings around 40lbs.
Reactions: 7 users
