What did you do to your G-Body today?
MrSony
MrSony
3,751
1,354
Des Moines, Iowa
I spent the morning installing a new oil pan gasket. Woo Hoo! Then since i had the engine lifted already, the afternoon pulling manifolds and sitting my headers ( Doug's full length) in the car. Tomorrow is header clearanceing and hopefully finishing up.
exhaust-header-bash-testing-powe-jpg.95603
+1ftlb, dyno proven.
O
oldsmobile joe
834
521
mpls
melloelky
melloelky
609
477
mass
sprayed my third and FINAL vacuum reservoir,this ones steel from an old jeep wagoner.the eriee thing is this mid 70's amc part bolts right up to the stock gm reservoir bracket.if this one crushes itself while hot & under vacuum,i've got bigger problems..
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
22,859
3,819
Kitchener, Ontario
I went to pick up some welding magnets to help out my son on a project so I had to take my GP for a spin, Glen Frey isn't with us any longer but he sure sounded great on his solo album that I have on a stick. I saw Glen Frey in concert when I lived in Florida and those songs sure brought back some happy memories. When I'm driving the GP I liked it that it is a 40 minute drive to my son's place......my mistake, it's 40 minutes by Jeep, 30 minutes with the GP...:)
F
focused313
266
177
Per you guys recommendations...I pulled my plugs...and gosh darn it that was a task. Those freaking headers made everything tough. I've never done it before so I actually enjoyed figuring it out. I have the new plugs but I forgot that I needed to gap them and of course I didn't have the tool. I changed the oil as well and there was barely any oil in there when I unscrewed the filter...yikes.
Hopefully I'll get a chance to get the new plugs in tomorrow. Will I be ok without a torque wrench?
oh yea...cut off a donor roof.
MrSony
MrSony
3,751
1,354
Des Moines, Iowa
I usually use a touch of antiseize on the plug threads up near where they start (minimizing chance of any getting int he chamber or on the electrode) and do 1/4 turn past finger tight. If you get them in by hand you can feel plenty well where they stop. 1/4 turn past that, check after a warm up and cool down cycle. As for the oil filter thing, could not have an anti drainback valve, letting oil drain back to the pan... just a guess. Put in the reccomended amount (5 quarts with filter change with stock type pans), and keep an eye on it. I check the oil when it's overnight cold so all the oil has drained down so I know how much is in the pan.
MTP-Madmat
MTP-Madmat
31
55
Put on some cheap plastic flares for now. Eventually I want to build some out of metal. The fenders have been cut for a while since I’m running a 315 square setup on 17”x11” wheels and 3.7” backspace. Next summer is going to be paint
00c4c879-eae7-4500-8947-432423952145-jpeg.95648
MrSony
MrSony
3,751
1,354
Des Moines, Iowa
Fixed my linkage problem. Took the linkage apart to clean the rust, grease, and undercoating off, then the column to shift lever rod (long one) decided it wanted to bind on the tab of the other lever. Put it in a vise and bent the skinny section of it away from the lever, goes into all gears like butter. idk why it suddenly started binding, but i dont really care. Also because I'm impatient and a tip from flemming, I drilled out the threads of one of my steel wheel lugnuts, wire wheeled the rust off, and it fits like a glove until my actual bushings arrive from Dixie. Also stopped being lazy and installed my regulator. No, it's not touching the intake. It's about 1" from it. Set it at 4.5psi. car runs better, feels like it pulls harder too. Also got the procedure down to get the 1-2 chirp. From a stop, 1/4 throttle, mash it halfway through 1st, some tire spin, catches, then the chirp. Makes me giggle. Stock 350 with a cam aint no slouch either.
TURNA
TURNA
4,475
2,589
Socialist NY
Sandblasted the Toronado air cleaner I picked up off CL
proxy.php?image=https%3A%2F%2Fimagizer.imageshack.com%2Fv2%2Fxq90%2F924%2FBtDV37.jpg&hash=0d7081992e72df3e142709a025e39d4f
proxy.php?image=https%3A%2F%2Fimagizer.imageshack.com%2Fv2%2Fxq90%2F921%2FIWGTi8.jpg&hash=b42905c58cf22020c850d78ef1781d66
Similar threads
