That's a lot better than I can do. Coppernick had a good suggestion to weld some plate on the back side if you can get to it. I am no welder, but I would be willing to give it a try. That said, since I would not be able to trust my own welding performance, I would also drill and bolt the plates over (both sides if I were able to reach) the repaired area, and then weld the bolts and nuts on too.Anyone order bubblegum?
I did manage to get the two halves realigned before I put those globs down, now I have to grind and prep a plate for tomorrow.
If I could take the axle out and was able leave the truck sit for a week I’d be doing that. GMT800 frames are a sort of semi boxed construction with about a half inch lip on the insides of the C channel, I have a lot of garbage to clean out before I can do that, but if I feel it needs it, I’ll be doing that in the future. I’m really just using this as an excuse to try rosette welds for a future brace setup on my Monte for a trunk shock mount.That's a lot better than I can do. Coppernick had a good suggestion to weld some plate on the back side if you can get to it. I am no welder, but I would be willing to give it a try. That said, since I would not be able to trust my own welding performance, I would also drill and bolt the plates over (both sides if I were able to reach) the repaired area, and then weld the bolts and nuts on too.
That's getting to my comfort level on a ladder. I'd need to do it regularly to not be a b*tch on the thing.
That looks like a 562xp... I have one in the same condition LOLPretty much lol... still a better starting point than this one 🙃
