pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Finally got back on the jeep to finish up the rad change, those jeeps take a long time to bleed the system. Maybe if I filled the system up by the bleeder like the instructions say it would not have taken so long. That Yaber booster pack I bought around 3 months ago was still 99% charged and the Jeep with a dead battery fired right up..... :popcorn:
MrSony
6,828
6,736
Des Moines, Iowa
Drove it in the first snow of the year. Did good. Granted it was only an inch or so of slush. That 160hp in a 4200lb package aint gonna get me into no trouble.
Local Hero
729
1,917
Northcoast, Cleveland, Ohio
Had to replace the wiper motor on the Cop Vic. Jr. came out of trade school on a beautiful bright sunny day and fired it up. The car went all "Christine-like" immediately when the wipers went on full-speed and the windshield washers emptied the reservoir. He drove all the way home without being able to shut anything off. Had he called me, I would have had him pull the fuse, which is what I did when he got here. A quickie google search alerted me that this is a common problem when the drain holes in the cowl pan under the windshield clog up and the mini circuit board in the wiper motor gets wet and shorts out. Replaced the motor and cleaned everything out and he's good to go from here on.
Also changed out the little bypass hose from the thermostat housing to the water pump on the Olds 350 in my D88. It was looking ready to blow. With it all back together and running it to purge the air in the system, I was hearing some not nice noises coming from the original stock clutch fan. After shutting it off, I wiggled the fan and got a considerable amount of play in the fan clutch. So last night I ordered an AC Delco replacement. Summit had them in stock and it will likely be here by tomorrow.
MrSony
6,828
6,736
Des Moines, Iowa
my dumbass ordered camper special shocks by mistake, rears use two through holes, "normal" rwd 250s use stud up top on the front and rear. So I only put the front shocks on (1000% improvement), a thermostat, screamed because the new sending unit I ****ing tested before installing in the tank stopped working as soon as I got the tank in and fastened up, despite me literally plugging it in a half hour before hand and seeing it work, and put an el cheapo Oreilly's dynomax muffler on.
did I mention that pos edelbrock is a pos? no? well it is. clearly worn slap out, definite throttle shaft leak, probably needs a kit, it's a ****ing 750 with a manual choke, so its too big and temperamental as **** when it's cold. As soon as I get the parts in that 403 olds qjet I have is going on.
  • Winner
Turbo Zach
2,534
5,874
Do you need a tissue?
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Spent today cleaning my garage, which of course led to a dozen other projects. Installed screens on the drain pipes from the footer and the gutters. Was concerned animals would climb up them and build a nest and cause them to plug.
Installed some roof edge trim on the lean to off the back of the garage that I've had for several months now. Forgot to snap a pic. Moved lots of stuff from the garage to the basement. Three propane heaters, a Rockwell belt sander that's in pieces (another project for me) and a mess of white wire shelving I was given to use for our closets. Installed new axle bushings in a customer's snowblower, made two trips to the dump to get rid of crap. Burnt a bunch cardboard and small scrap wood, fixed the air compressor by replacing the valve block on one cylinder, made a dozen no trespassing signs then installed them on land I hunt a mile down the road. Then hunted for just over an hour to finish the day out.
Reactions: 6 users
MrSony
6,828
6,736
Des Moines, Iowa
UC645
1,083
3,072
Kittanning, Pa
Installed my new self ejecting transmission cooler lines on the way home.
Thank Christ above I was only a quarter mile from home, managed to get it to 60 before I saw it start to slip and coasted into the driveway in a smoking like a freight train.
Hopefully it isn’t too hurt.
  • Wow
  • Sad
Reactions: 5 users
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Spent 3 bills having these things undercoated again. So no drag racing for me this weekend. Helps to wash the overspray off ASAP.
As expensive as it is, it beats having them rot away sitting in the drive way.
Reactions: 4 users
